Brief Description: Completed the Trim Servo access plate.
I dimpled the trim servo access reinforcing plate and installed the 7 K1100 nutplates in place. Then I back riveted the whole assembly onto the left hand elevator skin and screwed the plate in position.
There are two slightly high spots on the cover caused from two nutplate flush head rivets sitting a bit proud of the surface. The elevator skin is too wobbly now to attempt shaving the heads down so I will wait until the elevator is complete the carry out this task.
