Brief Description: Cleaned and primed all internal VS parts
I removed the vinyl from the inside of the VS skin. I have decided not to bother with priming the rivet lines of the inside of the skin from now on. I feel there is already primer on each spar and rib where the skeleton and the skin meet so I think it is unnecessary.I then rinsed all internal parts in warm soapy water, used a grey scotch bright pad with Laquer Thinner and scuffed up all surfaces. I wiped them dry and re washed them in warm soapy water. I rinsed them well and dried the parts completely before shooting with SW988 self etching primer.Next up is to rivet the understructure together and dimple the skin.
