Brief Description: Ground busses, master and start relays - Part 2.
I installed a terminal strip that I will use as an avionics grounding bus. I installed ground wires connecting the firewall ground to the left and right hand upper longerons. These longerons run the entire length of the airplane and make a good spot to ground electrical components.
