Brief Description: Ground busses, master and start relays - Part 1.
I removed the primer on the left and right hand upper longerons in preparation for mounting the ground busses. I used some Dow Corning Compound 4 between the mating surfaces and used Cherry Max structural rivets to install them. I wired up the master and starter switches, hooked up the battery and checked that both relays closed properly.
