I modified the battery tray by moving the nutplates aft about an inch to better accommodate the PC 680 battery (this tray was designed for the larger and heavier Concorde battery). I drilled the holes for the grounding bolts in the firewall then re-installed the battery, relays (and diodes) and hooked up the heavy gauge wires.
