Brief Description: Ground busses, master and start relays - Part 3.
I fabricated a brass strip that gangs all the No. 6 threaded posts together that will be used for grounding avionics. I ran No. 14 AWG in a twisted pair from the boost pump to the VP-50 CU and a ground bus on the right hand longeron.
