Today, I spent most of my time deburring, priming, and fitting the two end doublers on the right wing flap. This included a floating anchor nut on the inboard and brass bushings on both. Luckily, the temperature was in the 50s and no wind, so I primed both the frame and the skin outside the shop. In addition, I dimpled the leading edge ribs per the plans. I need to dimple the skin tomorrow. Then, the flap is complete until I can fit it on the right wing.
