Jerrys Web Site
Date: 6-22-2011
Number of Hours: 6.50
Brief Description: Main Wing Spars
This morning, I put the left main wing spar back in the jig as it is completely primed and ready to go. I double checked all the surfaces on assembly, deburring a couple areas that were still rough to the touch. In addition, despite advice not to, I followed the plans and prosealed between the doublers and spar caps in the fuel tank area. I made this decision after successfully using proseal (actually A2 from Seal Pak -- it's thinner) on my rivet practice structure. I simply mixed up a small amount, and spread a thin layer across the spar doubler surface with a craft stick (popsicle stick). I then added cleco's to each hole to hold it firmly together,
In the afternoon, I practiced riveting some more, then began to rivet beginning on the outboard section of the wing spar. Initially, I planned to do it myself, but at my experience level, it's much easier to have my wife Ruth help with the bucking. Out of the first 20, I drilled three out, all due to smiles on the mfg head of the rivet. A few of the shop heads are not perfect, but I'll wait and have my EAA tech counselor look at them and tell me which ones to drill out.
Left Main Spar Ready to Rivet
Close up of ProSeal in Fuel Tank Area
