Jerrys Web Site
Date: 3-14-2011
Number of Hours: 8.00
Brief Description: Trim Tab Area
Today, I completed reassembly of the trim tab, with 2 extra ribs and the new trim horn attachment. See the first two photos. Then, my first major problem. The Trim Tab Servo has a threaded rod that moves through it -- when I installed it, I centered it in the space allocated for the trim tab. Unfortunately, when I activated the trim tab servo, I was not able to see it and the aft threaded rod impacted and punctured the spar. After consultation with Ted Waltman, I decided to smooth the puncture with a bucking bar and hammer, and then drilled the hole to a 1/4" round hole with smooth edges, to remove the risk of stress cracks. The hole you see on the left of the spar in photo 3 is the hole for the trim tab wire to pass through. There is now a rubber grommet in the hole and the wire passes through.
Later I worked on afixing the servo to the backing plate. The plans call for #8 machine screws but the servo is built for #6. I had some on hand, but had difficulty holding the phillips heads while using a box end to tighten the nuts. There is not sufficient clearance for a socket.
Problems -- ugh. Lesson -- really plan ahead and save time. The plans are not very good, so it becomes important to carefully think everything through prior to the actual work.
New Trim Horns Complete
Close up of Trim Horn
Mistake
