Today, I did a little work on the tail where the elevator trim wire comes out. I also worked on the remaining hinges on the left wing, adding castellated nuts and cotter pins. Finally, I worked to tweak the aileron travel a bit and finished up some other miscellaneous things on the controls. Basically, I'm done except for waiting on a couple bolts/nuts to come in the mail. I have a bit of work to do on the wing to fuselage interface with wires etc.
