Vans RV-8 G-JBTR
RV-8 Build Log
Electrics
4-12-2011
Pre-Wiring TOP TIP
I was advised when doing the FWF to start with the immovable objects like the exhaust and plumb/wire around them.
I think the same advice goes to wiring the panel.
So far in my case the imovable objects are:
* Fresh air vent tubing
* Cables - Oil Cooler Door, Alternate Air Door, Parking Brake and Cabin Heat
* EFIS multipin connector mount
* Avionics Ground Bus
For these items I have made supports and p-clip support angles with nut plates.
It is surprising how long this takes to think/fabricate and you need to build into their locations your wire route plan.
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
