Vans RV-8 G-JBTR
RV-8 Build Log
Electrics
3-23-2011
Hinged Fuse Panel 2 - Catch
The catch was made from 0.032" aluminium and the left ones were 4.8" x 2" and the right was 4.8" x 2.5".
I don't propose to go into detail about how to bend because if you've got this far into the build you will be able to figure it out ;-)
The panels were 0.040" (suited my spare metal pile) and were 9" x 6.5" and 4" x 6.5"
I used a hand seamer to squeeze the catch throat as in the initial fit the panel was quite loose.
Completed installation
Catch 1
Catch 2
Catch 3
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
