Vans RV-8 G-JBTR
RV-8 Build Log
Electrics
9-27-2011
Cable routing tip
At the start of the wiring the wire routing bundles are very lazy and you need something to keep them together.
You can use cable ties but a much neater solution is thick rubber bands - another rare moment of originality :-)
Temp Cable Tie - Rubber Band
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
