Vans RV-8 G-JBTR
Date:  11-17-2008
Number of Hours:  0.00
Manual Reference:  8-2
Brief Description:  Firewall
I drilled out a few rivets because 1) I was a bit careless and 2) I was dull (rivetting nutplate rivets without nutplate!!!)
As the instructions say you can back rivet everything apart from the nutplates.
The only thing I found a little odd was the rivet call out in the corners. The metal thickness is the same but there are call outs for AD4-6's next to the weldments where access with a normal back rivet set is not so easy.
So I tried an AD4-7 in this location and it bent over slightly because I could not get vertical pressue with my normal back rivet set. So I went back to AD4-6's and they set just fine. I suppose if you have an extended straight back rivet set the 7's will be OK.
Impressions: Dimpling stainless steel with the DRDT-2 was a joy and I was very pleased with the overall finish. The really neat thing after the wings is you only have to do things once!
Rivet Call Out
Rivet Call Out
Firewall Aft
Firewall Aft
