The instructions tell you to rivet the nutplates first but if you look at the position of the nutplates on the Middle and Centre Right angle you will see that some inhibit you from back rivetting the AN426AD4 rivets.
My solution was to back rivet the Middle and Centre Right angles first and then rivet the nutplates. This turned out fine with no problems.
