Problem. When looking to install the Vans IO-360 Throttle/Mixture Kit it became obvious that the Superior Cold Air Induction Sump and its forward plug would interfere with the VA-164 Mixture Bracket- also the mixture arm provided by Aero Sport Power was a straight one (red circle).
1. Reducing the width of the VA-164 Mixture bracket 2, Inserting an AN932-05D Plug (may have to file down and re-paint) link for UK builders 3. You need a short offset mixture arm to clear the Sky Tek light weight starter - the required part number for the Silver Hawk EX-5VA1 Fuel Injection Servo mixture arm is 2521287
