Brief Description: Rear Throttle/2 Lever Deluxe Throttle Problem 2
I ordered the following: 4 x AN3-23A, 1x AN3-24A, 5 x AN365-1032 nylocs and a 10-32 die stock.
I made 5 x 1/2" x 5/16" spacers (left over from the aileron spacers - photo only shows four!) and I had a peice of 0.625" delrin drilled out to 5/16" and 1/2" wide from my delrin aileron stop modification. I also made a 1/2" angle painted black to fill in the inboard gap to prevent loose objects dropping into the quadrant.
I threaded the AN3-24A with the die stock to the same length as the removed bolt and then assembled it back. The clevis was smack on the throttle lever and I just have to make minor bulkead adjustments to fit the rear throttle pushrod without chaffing.
