Jacks Web Site
Date:  2-7-2009
Number of Hours:  3.00
Manual Reference:  ?
Brief Description:  Assembled base connector
I assembled the female connector and cable assembly. Pretty much the same deal as with the male side. The connector has a built in lock to prevent the halves from coming apart. You have to pull back on a collar on the female side to release the lock. Note how the connector assembly is easily pressed up into the tube.
Female cable and stick
Cables mated
Cables mated
Cable pressed up into tube
