Brief Description: Gussets, elevator bell crank, rear top skin
Clamped and drilled the forward fuselage gussets. Clamped and drilled the shoulder harness attach points. Made the bellcrank support parts and tested final fit in the fuselage. I clamped and drilled the aft fuselage gussets. Finally, I clecoed the aft skin to the fuselage. Each step makes it look more like a real plane.
