Brief Description: Installed side rails and gussets
I clecoed the side rails onto the longerons. I performed the modifications needed for the side rail gussets so that the arc cut into the gusset would be tangent to the side rails and the bulkhead. I then clamped and drilled the gussets in place on both sides.
