Sealed the right tank by reopening the seam and applying Proseal to the seam. Prepared the hole with nutplates to accept the cover. Used gasket compound to seal the cover. Did a leak test a little too soon and broke the seal after a few minutes of pressure. Resealed the seam and decided to let the Proseal cure before retesting. Assembled the tank to the wing.
