Installed the plastic electrical conduit in the right wing. This required the use of a jig to collapse the ribbed tubing so that it would go through the holes in the ribs. The holes were cut to fit the small diameter between the ribs, therefore the conduit will not move freely through the holes. By collapsing tubing, it goes through the holes and then can be expanded using a rod pushed through the tube.
