Brief Description: Drilled holes for ignition wires
Talked to Dave Edgemond about routing the ignition leads to the bottom set of plugs. He suggested that both sets of ignition coils should be mounted on the top of the engine to keep the installation clean. I started looking at how to do this and decided that holes could be drilled through the baffles to pass the ignition leads from the top coils to the bottom spark plugs. This keeps the leads short and relatively similar in length. Two of the leads provided are too short for this, so I ordered replacements from Lightspeed Engineering. I found rubber grommets that will fit the holes and go around the leads. I ordered these from DigiKey.
