Routed the fuel line from the fuel injector head to the fuel distributor. Drilled a hole in the baffle to pass the fuel line. Fabricated a bracket to hold the fuel line in place with an adel clamp. The fuel line provided by Aerosport Power is long enough to be cut so that a flow sensor can be inserted in the line. According to what I've read, this is the best place to put it from an accuracy standpoint.
