Brief Description: Installed 1st set of ignition coils
Fabricated the flanges for mounting the bottom set of ignition coils from .1" thick angle aluminum. Assured clearances between the coils and the engine block. Moved the fuel lines to clear the brackets. Fabricated a clip to keep the baffle halves together and to prevent chaffing of the ignition sensor wires.
