Jims RV-8
Date:  6-19-2021
Number of Hours:  3.50
Brief Description:  Prime doubler, standoffs, misc.
With the doubler on hold until I can get the correct sized nutplates, I shifted focus to next item on my current TO-DO list - the oil cooler mount on the firewall. I pulled out all the oil cooler parts and the mount that Bob sent me and figured I could remove the lower left rotisserie mount and have plenty of room to work in that quadrant. I would get everything marked and drill the holes and do a test fit it, and then I could remove it all until it was ready to go on permanently. However, I just wasn't comfortable drilling the holes in the firewall before installing the engine mount because if there is any unforeseen interference - then I was in a world of hurt. Some wasted time, but a good decision.
So, I pivoted to the cabin heat box control cable. I need to run the control cable from the right-side gear tower to the heater box control valve on the firewall. To do so, I needed to remove the smoke tank (again) and the painted lower baggage wall as I needed to cut a notch in it for the cable to run. After doing all of that I planned the standoffs for the cable supports and drilled them with the angle drill. I cleaned them up and primed them along with the antenna doubler.
I am also thinking about the oil cooler push/pull cable that will be running right along this right side to the other side of the firewall.
Cable standoff in place at the heat box valve
additional standoff for cabin heat cable
primed parts drying
primed parts drying
