Since I will likely now be using the Van's battery tray in the rear of the fuselage, I decided to get the parts out and and prep them for assembly. I de-blued, drilled, deburred and scuffed with the scotchbrite pad and then cleaned it up. I had a enough daylight left to shoot a few coats of primer...white as you can tell. This will have to dry over night and I can rivet tomorrow.
