Brief Description: Fuse Final Assembly – Riveting Outbrd Seat Ribs
Tonight I continued with the Forward outboard seat ribs and riveted them to the L/R center bottom skins. I used a modified back rivet set up with the big hand held flat faced bucking bar. It worked out well – although I did have to drill out 3 rivets and do them over. Then I riveted the F-805G gussets to the F-805 bulkheads and riveted the nutplates to the Aft arm rests (F-860C). That’s it for tonight… more work tomorrow night as Teresa has plans with her dancer friends
