Today I continued with the right wing - I clecoed the wing ribs/main spar/rear spar together - final drilled all the holes and then disassembled. I was able to debur both main spars and both rear spars - and deburr the right wing main ribs. Next I will debur the left ribs - clean them up good - prime them and rivet them together... but that will take a few sessions. I also have to think about the plumbing runs for pitot tube, lighting wires, AOA wiring, etc. The usual process is to run conduit thru the wings to carry the wiring - so back to the computer for more research and decisions.
