Jims RV-8
Date: 8-19-2023
Number of Hours: 1.20
Brief Description: Engine #11 - Oil filler neck tighten
When Joe was over to install the engine, he pointed out that my oil filler tube was a little loose, and today, that got corrected. I cut off the old safety wire, removed the tube, cleaned it up a bit, then applied Permatex, tightened it back up, and safety wired it. I am tired of using this cheap pair of safety wire pliers, so I ordered two (6" and 9") quality safety wire pliers, which are currently on backorder. I also found another place for a safety wire redo but after a few unsucessful tries, I will wait for the better pair of 6" pliers. Always check your work and other people's work too, even the "experts".
During
After
Another safety wire redo candiate
