Jims RV-8
Date:  6-26-2021
Number of Hours:  1.00
Brief Description:  Oil Cooler valve rivets
I still had some shop time this morning and saw that I could rivet the nutplates into the oil cooler valve plenum - so that's what I did. I first drilled the 4 screw holes out to 5/32" using the #19 bit. After deburring the holes, I put the screw thru the nutplate to line up the screw hole while I drilled the rivets holes for the nutplates. I then used the DRDT to countersink the rivets holes, then riveted the nutplates to the housing. Easy breezy – check that off the list of things to be done.
Now I just need to rivet the cable support
nutplates riveted
nutplates riveted
