Brief Description: Adhering the LED light ends/wires
As the manufacturer glue used on the LED lights is not super awesome, there is a tendency for the wires that are currently unsupported to pull on the LED lights that are hanging upside-down and is causing them to pull away from the aluminum skin. Eventually, the wires will be supported but until then, this needs a fix. To remedy this, I pulled out some surplus sika flex to better adhere the wire bases. I did two of the top wires and left them to dry. On second thought, since sika take a activator, primer and adhesive – it’s a little more than needed for these wire bases. I will go pull the 3M 1300 adhesive out of the refrigerator and let it warm up for the next round of wire base adhesive.
