Brief Description: Routing path of aft strobe wires
I worked on the routing path of the shielded wires that will go from the front all the way to the aft tip of the rudder where the position / strobe light is located. As I was reading thru the installation instructions and cross-checking what I knew to be with what I thought to be, I realized that I had ordered the 22 gauge shielded wires instead of the 20 gauge, which is slightly larger. After discovering that mistake, I double checked all the rest of the aeroLED wiring diagrams to make sure that I didn't make any other mistakes and then I placed an order for the correct shielded wires. I also added some other installation hardware to the order that will be needed for the install of the LRC3 voltage regulators, the diode and other misc. things. While I had some time, I also decided on the remaining buss locations.
No pictures as there was no visual progress, just planning and mental progress.
