Jims RV-8
Date:  12-27-2023
Number of Hours:  1.80
Brief Description:  Flap Relay wiring
I started the flap relay wiring and decided I would like to route the wiring to exactly where the flap relays were going to be mounted, so I made a small blank out of scrap aluminum sheet which would simulate the floor for that area, and I could mount the relays exactly where they will end up without having to have the floor installed. I am using the Steinair relay, just like on the smoke pump motor, but I am having difficulty translating the wiring diagram from the single motor activation to the dual motor activation. My buddy Ralph provided a great schematic, but the numbers were small when printed out, so I drew the schematic to refer back to. I also wanted to confirm my understanding of the relay, so I tested the smoke pump motor functionality, and sure enough, when I ground the pilot stick wire for the smoke pump, the "smoke on" light was illuminated, and the motor could be heard (just a short test so as not to damage the pump). Test successful!
