Jims RV-8
Date:  10-15-2023
Number of Hours:  1.70
Brief Description:  AoA indicator location
I clecoed the glare shield on and put the windscreen in position to see where I might want to locate the AoA indicator. Since most traffic patterns tend to be left-hand, it makes sense to locate the AoA readout cheated over to the left side of the glare shield. It took a while to install the glare shield, some flooring, and the seat cushion, but sitting in the pilot seat with the glare shield on and the windscreen in place makes for a more accurate assessment. I played around with a few locations from about 3" from the center of the glare shield to the far left and settled on somewhere between 3"-4" as the optimum location. I also decided I needed to paint the underside of the front skin where it extends beyond the panel, as that primer is very light compared to the rest of the gray interior.
Pilot view
Pilot view
