Brief Description: Pre-engine installation work #2
While Bob was working on that stuff, I was on the engine doing stuff that should be done before the engine is mounted and there is no room to work. Occasionally, we would help each other out. Bob had already installed the prop governor temporarily, so I torqued the nuts, and we both reclocked the actuator arm and got the prop governor cable bracket to fit with the unique screw hole pattern. That was a tedious affair. I torqued those screws and safety wired the prop governor actuator arm screws, safety-wired the manual tachometer cap, and installed the prop governor actuator cable. I marked the torqued fasteners with witness paint. With so much good progress, we are feeling good about scheduling Joe for tomorrow - so next we need to locate the hardware for the engine mount.
