Jims RV-8
Date: 6-4-2023
Number of Hours: 1.60
Manual Reference: 10-3
Brief Description: Landing Gear Fairing #4
Using the measurement of the top and bottom of the landing gear as a guide and comparing that to the inside dimension of the gear fairing, I slid the hinge forward a bit on the left gear fairing in hopes that it would provide a tighter fit. I will still need to use the expanding foam inside the gear fairing, but I hope to improve the fit if possible. I measured, marked, clamped, and drilled the bottom and top of the fairing and hinges.
After all the marks were drilled and clecoed, I slid the hinge pin into the hinge halves and realized there was quite a bit of tension with the hinge pulling the fairing together. That was the original intent, but it's likely pulling too much, as the hinge pin is difficult to insert. I will take another look, but I think I will need to re-drill the hinge farther aft, allow the gear fairing to be thicker, and plan to use more interior foam.
bottom of the left gear fairing hinge drilled
Top of left gear fairing hinge partially drilled
test view with hinge pin installed
