Jims RV-8
Date:  12-31-2022
Number of Hours:  0.90
Brief Description:  Smoke Pump Wiring #1
I started wiring the smoke oil pump. I use a push button switch on the pilot's stick to turn the pump on/off. I also run the circuit thru an enable switch so that I do not turn the pump on at an inopportune time. The pump is a 4A pump with a 4A draw, so I am running the circuit thru a relay.
The first thing to do is to get the wire from the power source to the switch and then back to the relay/or pilot stick. My friend Ralph, who has built Van's RV and is also a friend of Bob, has offered to help with the documentation of the circuitry - so I am taking him up on it.
While I am here, I am also wiring the defrost fan (blue wire) wire set too. I labeled the green Smoke pump power wire, terminated it, and temporarily zip-tied it in place.
As the year comes to a close, it marks the 10th year that I have been working on the project.I started on 10/28/2012. I put in 247 hours in 2022, which ranks 5th most compared to all the other years...gotta get after it.
green and blue wires at the power source
green and blue wires into and out of the conduit
