Jims RV-8
Date: 8-25-2022
Number of Hours: 1.70
Brief Description: ELT Wiring to remote switch
ELT wiring is complete. I joined the three conductor wires coming up from the aft/ELT location with the wire harness wire. While shortening the wire to the correct length, I realized that AFS used a two conductor wire for the ELT signal wire. So I capped it with shrink wrap, just as they did. Using a solder sleeve for a splice, I joined the blue/white wires, which allows the ELT to pass along the location from the GTN-650Xi. I also tied the shields together, even though it is likely overkill, as it is easy to access right now. Then it was a matter of printing wire labels, stripping the remote switch wires, crimping the Molex pins, and triple-checking the correct wire location before inserting it into the Molex connector. I forgot to take the "during" pictures, so all you get is an "after" pic.
ELT remote switch wires done
