Brief Description: Alternator and Starter power wire
I decided to change out the power source of my Alternator (1 and 2) and starter power from two wires to one wire. Initially, the thought was for redundant sourcing, but upon further review, I decided one more robust wire would handle more load and work better. I made the wire switch which amounted to removing the two and installing the one, then undoing the lacing work at the right-side panel switches, and then re-doing the same lacing. I started working on wiring the CB bank to finish the session.
