Jims RV-8
Date:  6-5-2022
Number of Hours:  1.40
Brief Description:  Add Alternate Static Air switch
I disassembled the panel to drill the hole for the alternate static air switch. Since the panel was out, it was also an excellent time to remove the 4th row of breakers and remove the "E-Bus" label that will be changed to GMU-11. I also changed out the 7.5A circuit breaker for the 2A CB. Now I need those panel labels to show up.
switch in and label test done
