Brief Description: New Battery Bus label and install
I needed to move the Battery bus farther to the right side of the access door to enable more room for the avionics stack. I didn't want to drill more holes in the access door, but at least it is lighter now. I went to the new, smaller battery bus, so I had to re-label it and the two slots, and then I worked out the best place to put it on the access door - given the remaining options. I then drilled the holes, cleaned up the holes with the debur tool, and installed the bus with screws, washers, and nuts. I also worked out the remaining wiring on the bus sense/overvoltage lamp combined wiring.
