I purposely had the power wires at 36" length, as some of them go around to the fuse buses while the others are powered thru circuit breakers. So gathering the power wires allowed for a service loop and then separating them by fuse/CB. I then realized that the fuse wires did not need the same service loop as the loop was just in case I wanted to remove the panel; the service loop will allow the panel to extend far enough to lay the panel out of the way.
So, I cut the lacing back to the beginning of the service loop, separated the fuse/CB wires into two sections, laced the fuse wires together, and then laced the CB wires together.
During this time, I wrote up some email questions to AFS regarding the extra power wires and took part in the obligatory thinking, re-thinking, and over-thinking I tend to do.
