Brief Description: More Fiddling with the Batt Bus
I did some more fiddling with the battery bus as it will have to move out of the way of the avionics stack wiring. I don't need too many ports on the battery bus, so I was looking at downsizing the bus, moving it around, and changing the orientation.
A few options are: 1. move the battery bus to a different location 2. move it over slightly in a vertical orientation 3. flip it horizontally and move it slightly 4. move the second bus over slightly and then move the battery bus over even more
Any way I go (except #1) will put more "lightening" holes in the access door, so I will have to decide if I care enough to replace the access door at some point or just build on.
