Brief Description: Clean up shop - fiddle with batt bus
I put a good clean-up on the shop to convert it into wiring mode, so that means I put up all the non-essential tools and pulled out the wiring cutters, stripers, multimeter, and crimpers.
Also, in preparation for laying the wiring harness in place in the cockpit.
I cleaned up the main trunk area and made sure that all the other wires were out of the way. Knowing it would be an immediate 180-degree bend for the avionics stack wires, I re-ran some of the relay wires running over and under the bus wires so that they now all run under the larger bus wires to tidy things up. I also temporarily moved the battery buss one screw hole to the right in hopes that it would be enough to alleviate interference. I can permanently mount it if so.
