With the primer left to dry overnight, I riveted the nutplate and the sheet to the angle – then tested the cradle supports…only to find that the larger angle will need to be trimmed to fit in the available space. I trimmed one support angle and they both now fit, but I will likely trim the other bottom support as it will be plenty big and strong, even after trimming.
