Brief Description: More #2 wire securing - forward of spar
With the aft portion of the #2 wire secured, I continue forward securing this big wire in place. The idea is to keep it from moving around and chaffing itself or wiggling up and down and weakening the individual strands of wire. This wire is so big that is not very likely, but I am securing it all the same. I now have the wire secured thru the exit point thru the firewall pass-thru, but I would like to make one more support between the wing spar and the gear tower as the fuel lines and filter sit right there under the left side console. I pondered that for a while and think I have a good solution. More on that later...
I also riveted the four nutplates in the cradle to hold the backup battery.
