Jims RV-8
Date:  9-16-2021
Number of Hours:  4.00
Brief Description:  Avionics Stack Support Angles #2
Worked the angles until I was happy with the final fit and finish and then marked the angles for drilling. After the angles were punched, drilled, and deburred I put them back in place on the back of the panel and match drilled the holes to the panel
After the angles were drilled, I started looking at where I would like to mount the three remote boxes and the backup battery. Lots of head scratching with this exercise and although I haven't locked in where I would like to mount them all, I have some good ideas and potential good locations. I also worked out in my mind where the rear stack support will tie into the bulkheads/supports and where the wires will be routed...so good progress.
front side panel view
aft panel view
aft panel view
one option for the transponder
