With the LEMOs done, it was on to the right-side panel labels. I had to mark and remove all the switches and dimmers to get an even surface and get the side panel out of the cockpit which made the application of the labels much easier. The application of the labels was more labor intensive than I thought it would be because on the side panel I had drilled the anti-rotation holes for the switches but did not account for them in my label dimensions so in a few places there was a hole where a letter or line would be, so I had to do some slight shifting of the labels to address that issue. It all worked out and I got the labels applied, it just took a little longer...as per usual.
