Jims RV-8
Date: 5-23-2021
Number of Hours: 3.90
Brief Description: Side & Other Panel Labels
More label work - first I needed to remove the "Master" label on the center panel. I tried soaking it with water by letting water completely cover it for 30+ minutes, but that did nothing - I guess I am glad for that. I next tried to scrape it off with the plastic ruler edge, but I accidently scraped off some label and paint underneath so now I will need to fix that... sheesh. In the end, I applied painters’ tape and pulled the label right off - I wish I would have tried that first. I did test the labels that were sprayed with the acrylic after the adhesive dried and they do not come off with tape. So, I will apply a "spare" label and then not spray it with acrylic so that it can be removed when needed. I cleaned and painted the scratched area of the panel - all the above took about an hour.
Next, I worked on all the other labels for the right-side panel, the pull cables for the alternate air, oil cooler, parking brake, cabin heat and the rear push-to-talk (PTT). This means spacing, wording, etc., etc. but I think I have it worked out.
right side panel - getting close to wrapping those wires
slight adjustment - not much room
here or middle of center panel - what do you think?
